Subject Topic: newbie- 1994 Chris Craft 21 bowrider Post ReplyPost New Topic
pykeboat
Posted: July 07 2009 at 11:24 | IP Logged Quote pykeboat
Hi everyone.  I thought I would make a post regarding the boat I am looking at buying.  I am not that farmiliar with Chris Craft boats, but it is a 1994 21' bowrider with a 5.0 engine.  Looks in good shape and I am trying to get it checked out by a mechanic.  Any advice or things I may want to look for checking this boat out?  Anyone own a similar model?
thanks.
Edited by pykeboat on July 07 2009 at 11:25
Back to Top Printable version View pykeboat's Profile Search for other posts by pykeboat
Banjoman
"First Mate"
Posted: July 07 2009 at 12:51 | IP Logged Quote Banjoman
Good to have the mechanics looked at, but do not forget the hull itself!  Call a suveyor and have the boat surveyed!  www.marinesurvey.org  will put you in touch with the Society of Accredited Marine Surveyors.  Follow their site map to find one in your area.
A good engine won't do you much good if the transom and/or stringers are rotten!
Capt. G. Emory Shover
m/v "SOUTHERN CHARM"
Eastern Marine Services, LLC
www.easternmarineservices.com
pykeboat
Posted: July 07 2009 at 13:36 | IP Logged Quote pykeboat
IS this not a fibergalss boat?  Is there wood inside that can be rotten?
Banjoman
"First Mate"
Posted: July 07 2009 at 21:41 | IP Logged Quote Banjoman
All stern drive boats have fiberglass skin over wood transoms.  Most wood is plywood (called core) encapsulated by the fiberglass skin.  However, many production boat builders do not do a very good job of sealing the cut-out for the drive and over the years water can (and will) migrate into the plywood core.
As for the stringers.....same thing.  Most are glass over wood core, but not all.  Your 1994 Chris most likely has wood core.  It gets a little more complicated than this, but you get the gist of it.
At 21', I am not sure if your decks are cored or solid fiberglass.  But another reason for hiring a qualified surveyor is that voids or delmaniation can also be discovered in the fiberglass bottom or deck.
Just because a boat is fiberglass does not mean there cannot be problems with the lay-up of the glass.
I am surprised that your lender and/or insurance company is not requiring a survey.
pykeboat
Posted: July 08 2009 at 10:56 | IP Logged Quote pykeboat
I am in Canada, so you will not get any bussiness from me, if that is what you are trying to drum up here...
I was looking fro comments form someone who may be familiar with this boat.
Banjoman
"First Mate"
Posted: July 08 2009 at 11:31 | IP Logged Quote Banjoman
pykboat - sorry if you took my well-intentioned advice as "drumming up" business.  I live in the USA in the Old Dominion State of Virginia and certainly have no intention of surveying boats in your beautiful country.
I do not advertise on this forum, but I do try to offer up some common sense advice from time-to-time to help out my fellow boaters.
By all means, forget my advice and by the boat.
Have a safe and happy boating season!
bpblake1
Posted: July 08 2009 at 13:27 | IP Logged Quote bpblake1
Pyke,
I think your response was a bit out of line.  Banjoman was giving you very good advice...regardless of what particular boat you are buying!!
You will find the vast majority of people here are willing and anxious to help because they are advocates for the boating lifestyle, not because they are trying to drum up business.
Best of luck to you!
Edited by bpblake1 on July 08 2009 at 13:28
Back to Top Printable version View bpblake1's Profile Search for other posts by bpblake1
pykeboat
Posted: July 08 2009 at 13:32 | IP Logged Quote pykeboat
OK thanks for the "Input" on my topic, very helpful.
