Subject Topic: Lowrance 3500 sonar Post ReplyPost New Topic
Doral Dude
Posted: June 29 2009 at 18:25 | IP Logged Quote Doral Dude
My 2005 Monticello is equiped with a Lowrance 3500 digital sonar that has worked fine until this season. When the boat was launched, the depth sounder flashed .5 feet. Subsequent attempts to get it to work have failed. At one point it went blank when I started the engine, then got back to flashing .5' the next time. All I get at the Lowrance service center is a busy signal. Marina service manager suggests it might be the transducer which is thru-hull. I don't want to haul the boat but am concerned if I do any cruising away from local waters.
Anyone out there have a similar problem or any ideas? Could I have messed up when I reinstalled the batteries this spring? I did step on the transducer accidentally and one of the trailer rollers was partially on the bronze thru-hull (but it was that was in previous years).
I'm away from the boat for two weeks and hope to find out whats wrong before I get back.
Thanks.
DD
INWATER
Posted: June 30 2009 at 22:42 | IP Logged Quote INWATER
I have been told that the digital depth finders are good for about a season and 1/2. My experience has been pretty close to that!
Larry
Back to Top Printable version View INWATER's Profile Search for other posts by INWATER Visit INWATER's Homepage
Doral Dude
Posted: July 01 2009 at 15:50 | IP Logged Quote Doral Dude
Larry,
Is it the transducer or the gauge that goes bad?
INWATER
Posted: July 01 2009 at 22:50 | IP Logged Quote INWATER
DD
Sorry I can,'t answer that. I usually buy both at the same time. The last one I replaced was no longer being made and the old transducer was not compatable with the new model.
Larry
This page was generated in 0.8125 seconds.
