Subject Topic: Rebuild or replace Post ReplyPost New Topic
partgypsy
Posted: February 19 2009 at 14:00 | IP Logged Quote partgypsy
I picked up a Catalina 35' aft cabin "project" for cheap and it looks like I might have to replace one or both engines. One engine will not turn over and the other clanks alarmingly. I filled the seized engine completely with ATF and let it sit for 3 months and it still won't budge. The engines are possibly the original 1974 and I feel that replacing might be the best return on investment. I can get remanned blocks for about $1600 apiece and can do the wrenching myself with the help of a mechanic friend.
My big challenge is how to swap the engines in and out of the engine room. They have to in to the main cabin and then through the floor hatches. No way they will go through the hatch or the side windows intact.
I only see two options:
1- I will have to do some surgery on the cabin top. There does not seem to be a pre-framed opening as in some of the larger Chris models, so I don't know how best to proceed.
2- I could disassemble the engines and bring them in in pieces. That would be a lot less work and damage, but
Has any one done this operation before and if so, what worked best?
Back to Top Printable version View partgypsy's Profile Search for other posts by partgypsy
markweller
Posted: March 17 2009 at 23:12 | IP Logged Quote markweller
Small block chevys will fit through the cabin door trust me I know I did it you will need to remove all front end equipment alt, water pump etc and the exhaust manifolds the heads can stay on you need to go up to the top part of the door then out I used a chain hoist hooked to the rack tow motor at my marina after clearing the door I just had them lift it and set it in the back of a pickup oh the hard part is moving it from the engine bay to the door way I just lifted set it down on 4x4's and slid the hoist over lifted etc over and over till it was at the door way. If you want I can send pictures of the hoist I used to get it out of the engine bay.
M Weller
1975 35 Double Cabin
350Q Motors
Back to Top Printable version View markweller's Profile Search for other posts by markweller
partgypsy
Posted: March 18 2009 at 11:19 | IP Logged Quote partgypsy
Mark... you are the man! Someone who's actually done this before.
So the heads can stay!! This is particularly important in installing the new engines as I wouldn't have to pull them and re-install them. We are a very small self-help boat club with no equipment, but plenty of strong backs and ingenuity. Photos and ideas would be great. Others might benefit from this as well.
Thanks!
markweller
Posted: March 18 2009 at 14:02 | IP Logged Quote markweller
you can go here and see this thread and more on the rebuild of a chris craft q motor at the master index but here is the hoist thread
http://www.network54.com/Forum/424840/message/1197132572/Mot or+Issues
if you want pm me and I will get you my phone and email for any help you may need.
M Weller
350Q Motors
This page was generated in 1.3594 seconds.
