Subject Topic: rudder bushings. Post ReplyPost New Topic
Capt. Heavy
"First Mate"
Posted: January 15 2009 at 13:20 | IP Logged Quote Capt. Heavy
Got a surprise the other day as I was adding extra bonding wire to my rudder posts. I had to remove the rudder plates to access the rudder tiller arms. I removed the collar on top of the rudder posts, then the four lag bolts that hold the plates in place. The new rudder bearings (bushings) I installed last summer were corroded. They were supposed to be an alloy that was resistant to corossion. The plates are stainless, the rudders bronze. Any way, I ran an 8 gauge wire from each tiller arm to the ss plates, and from there to the copper bondtng strip that runs throughout the boat. Instead of using metal bushings again, I bought nylon bushings impregnated with molylube, and are supposed to be self lubricating. That should take care of that problem. Steering feels nice and smooth. And for once everthing went together pretty easy. There is no room in the lazarett because the fuel tanks are only about 1 1/2 feet en front of the transom. No way I can get down there. So I bring down a portable compresser and use an air tool to remove the bolts, while hanging upsidedown. The factory plates were plain steel with no bearings. Real smart. Now onto the oil and filter change. See ya, Capt. Heavy
Capt. Steve, Stuart Fl. Chris Craft Owner- 25 catalina, 331 corinthian. Licensed Capt. 20 Years, Certified diver for 30 years. Avid fisherman.
Back to Top Printable version View Capt. Heavy's Profile Search for other posts by Capt. Heavy
This page was generated in 1.1875 seconds.
