Last Post By: laoutdoors
Posted: Today at: 10:30
Uniflite
Subject Topic: Removing the electrical box on my Onan Post ReplyPost New Topic
BoatRDavid
Posted: December 01 2008 at 21:01 | IP Logged Quote BoatRDavid
The water heater on my '84 42' Double Cabin has failed.  I purchased a new one, but the R & R is going to be difficult because the heater is located far on the port side, outside the Onan 8.0 kW (8.0 MDKD-3CR 1A).  And the heater is 18 3/4" in diameter.  The only way to do the exchange is to tip it on its side and slide it out over the back of the genset, AFTER the electrical box is removed.  Anyway, this job is worse than I expected.  I'm not sure how it is going to work.  The only thing I can see to do is to disconnect about a hundred wires in the electrical box and remove the box.  That is what I had planned to do, but it is going to be harder than I thought.  I even measured other areas that might provide access such as removing the cooling system from the port engine or cutting a hole in the sole.  None of those will work.  I'm going to squeeze my way in there tomorrow and start testing (for power), tagging, documenting and removing wires.  Anyone have any thoughts on this project?
David M. Oates
42 Uniflite SE II, Adventure
San Francisco Bay Area
