Subject Topic: unknown water leak source Post ReplyPost New Topic
maxiestaxi
Posted: November 25 2008 at 19:53 | IP Logged Quote maxiestaxi
I have a 1995 300 express cruiser and have developed a water leak froman unknown source.  Water builds up in the bilge area beside the water tank, Can not find the source. checked tank, no apparent lines leaking.  first noticed wet carpet in front of entry steps? any suggestions?
Michael Longanecker
Back to Top Printable version View maxiestaxi's Profile Search for other posts by maxiestaxi
Mo's Toy
Posted: February 03 2009 at 17:12 | IP Logged Quote Mo's Toy
  I had a similar problem on my 270DA. I would only get water in the bilge when it rain and I had it in a covered slip except the front three feet of the bow. I had to seal the entire rub rail on the one side to get the water to stop coming in behind the holding tank area. It now remains dry all the time. You may try that as it runs down the joint to a low spot then drop off.
Back to Top Printable version View Mo's Toy's Profile Search for other posts by Mo's Toy
sanchita
Posted: June 01 2009 at 00:42 | IP Logged Quote sanchita
Had a pesky hard to find leak on my 270 amberjack. Wet carpet just like you mentioned.
The problem was a loose compression fitting on the a/c drip pan. Tightened as best I could, then put silicone inside and out. The sump has been dry since.
Back to Top Printable version View sanchita's Profile Search for other posts by sanchita
captdosr
Posted: March 14 2010 at 15:12 | IP Logged Quote captdosr
I had same problem on 88 express but on starboard side problem was seal around fixed windows scrades out old silicon and resealed problem fixed
Back to Top Printable version View captdosr's Profile Search for other posts by captdosr
sanchita
Posted: March 15 2010 at 01:23 | IP Logged Quote sanchita
you might check water getting around the nav lights, especially if changed lately, or where safety rails are mounted to the deck.
sanchita
Posted: March 15 2010 at 07:49 | IP Logged Quote sanchita
although not an answer to finding the leak, you may consider installing a rule computer controlled bilge pump that kicks on every 2.5 minutes. if it senses resistance it keeps pumping, if not it cuts off. Beats the wet carpet problem while looking for the leak.
fmvmusicvideo
Posted: February 17 2011 at 06:37 | IP Logged Quote fmvmusicvideo
Thanks for the post.
best music video
free music video
Back to Top Printable version View fmvmusicvideo's Profile Search for other posts by fmvmusicvideo
This page was generated in 4.7651 seconds.
