Four Winns
 BoatUS Boat Groups/Manufacturer Forums>>Four Winns
Subject Topic: Four Winns Gauges Post ReplyPost New Topic
Bayfly
Posted: October 17 2008 at 00:52 | IP Logged Quote Bayfly
I have a 04 214Fs and would like to either improve the lighting of the instrument panel or replace the gauges with ones that are better illuminated. The ones I have now are well lit around the edges but the dial itself is unreadable at night. Can anyone suggest a fix or replacement gauges? One of the gauges is a 4 function gauge. Who manufactured these OE gauges? Any help is appreciated.
Steve
Back to Top Printable version View Bayfly's Profile Search for other posts by Bayfly
EvilZ
Posted: July 28 2009 at 19:41 | IP Logged Quote EvilZ
I believe the gauges are made by Faria.
http://faria-instruments.com/marine/index.php
Back to Top Printable version View EvilZ's Profile Search for other posts by EvilZ
NWBoater
Posted: March 01 2010 at 01:16 | IP Logged Quote NWBoater
I ordered my '07 Horizon 220 with a Mercruiser package and then switched all of my gauges to Smart Craft ones. I didn't like the 4 in 1 type, it's too hard to get much resolution of values. The new gauges are separate from each other, and each sweeps 3/4 of the way around the dial. In addition, I replaced the speedometer and tach. Now I also get miles per gallon, gallons per hour, miles until empty, etc. The lighting is much better too.
Back to Top Printable version View NWBoater's Profile Search for other posts by NWBoater
Bayfly
Posted: March 01 2010 at 19:31 | IP Logged Quote Bayfly
Which gauges did you replace since the 4 in 1 took up such a small space and to replace it with individual ones means leaving some out in the replacement?
Steve
NWBoater
Posted: March 03 2010 at 11:33 | IP Logged Quote NWBoater
I thought I took a picture of the new dash but I can't find one. If you're interested, I can take one after I uncover the boat for the summer.
I replaced the whole dash. All of the original gauges are gone. The replacement speedometer and tach are the same size. The other gauges are: fuel level, voltage, oil pressure, water temp, and trim. I have a separate GPS unit I installed, so I didn't care about loosing the compass. The GPS also shows depth so I didn't use the original depth sounder.
