Subject Topic: packing gland/stuffing box Post ReplyPost New Topic
kareno
Posted: October 03 2008 at 11:50 | IP Logged Quote kareno
Does anyone know if there have been problems related to the packing gland or stuffing box on older sea rays?  We have a 1984 34' sundancer which just partially sunk at the dock.  Insurance says it may be a maintenance issue since water was coming through the shaft.  The packing gland was replaced at the start of the season & periodically checked.  We have never had water in the bilges, etc. & we used the boat all summer.  Any input??
Back to Top Printable version View kareno's Profile Search for other posts by kareno
KG4VGH
Posted: October 05 2008 at 17:19 | IP Logged Quote KG4VGH
Kareno....
I have a 1990 and the glands weep briefly after a cruise....nothing major....A thought....when the new packing was put in...the packing nut may have been turned to tight and scored the shaft...once it is scored...no amount of packing will help....could have also been that way prior to putting the new packing in......might also check the rudder logs.....as that also is a source of water entry into the bilge...
Pete
1990 SeaRay 340
Julia Rose
Hampton Roads, VA
mmsi 338030905
Back to Top Printable version View KG4VGH's Profile Search for other posts by KG4VGH
kareno
Posted: October 07 2008 at 11:18 | IP Logged Quote kareno
Thanks for your response.  Just spoke with the insurance guy - they're denying the claim based on improper maintenance or wear and tear.  He claims that since he saw water  coming into the boat from where the shaft log is, that that must be the reason.  He never inspected the shaft log, the packing, etc.  He says that since he saw water coming in that the only reason is that it was improperly maintained or packed wrong or wore out since the beginning of the season.  He says there can be no other reason the boat took on so much water.  Now we need to appeal it - have to find a lawyer, I guess.  I just think that he can't make that decision without inspecting the part, etc.  But he disagrees.
KG4VGH
Posted: October 07 2008 at 19:15 | IP Logged Quote KG4VGH
I would before I did anything....get a second opinion on it....maybe even a third.....if you appeal...you will need them......there are just to many ways for water to get into a bilge....to decide one just one without an inspection.....
Pete
1990 SeaRay 340
Julia Rose
Hampton Roads, VA
mmsi 338030905
kareno
Posted: October 07 2008 at 20:40 | IP Logged Quote kareno
An expert meaning a mechanic or a surveyor?
KG4VGH
Posted: October 08 2008 at 20:50 | IP Logged Quote KG4VGH
surveyor or even better an independent Marine Insurance Adjuster...don't know if a mechanic would have the necessary credentials should you end up in court
1990 SeaRay 340
Julia Rose
Hampton Roads, VA
mmsi 338030905
kareno
Posted: October 09 2008 at 09:10 | IP Logged Quote kareno
thanks for you help.
This page was generated in 0.9512 seconds.
