View Last Post fuel gauge
Last Post By: Bunka
Last Post By: Bunka
Last Post By: Trawler
Subject Topic: REVERSE PROBLEMS 251 CATALINA Post ReplyPost New Topic
MATTYJIVS
Posted: September 26 2008 at 14:40 | IP Logged Quote MATTYJIVS
I HAVE A 251 CATALINA 1976   307 W/PARAGON TRANS
SHE GOES INTO REVERSE BUT SLIPS WHEN I GIVE HER GAS,FORWARD IS GREAT,ANY INPUT WOULD BE GREAT THANKS
MATTYJIVS
1976 CATALINA 251
Back to Top Printable version View MATTYJIVS's Profile Search for other posts by MATTYJIVS
boatman66
Posted: September 27 2008 at 09:44 | IP Logged Quote boatman66
First,check the fluid level,if okay move on to the shifter cable,it may be out of adjustment and not engaging the reverse selection all the way..the best way to do this if by yourself is to engagae the shifter to reverse (engine not on )disconnect the cable at the trans shifter lever,and see if the lever moves futher to the reverse position,if it does,and it may not be much movement,the cable needs tuning.if not the cable, your problem may be in the shift lever itself not going all the way into reverse. I seriously doubt that the trans itself is the problem it may be,but exhaust all other potential areas first.there are also adjustments to the cables on the shifter itself look for them. AND GOOD LUCK
1986 294 catalina twin 350's
This page was generated in 1.4063 seconds.
