Subject Topic: ignition issues Post ReplyPost New Topic
patdaddy
Posted: September 01 2008 at 11:00 | IP Logged Quote patdaddy
sudden issues with port engine. ignition switch is a three position. first position off, second position, system on, third position, engages starter. all works well at this poiint. gauges ok, starter spinns, engine lights, but will die the instant you ley off the ignition from start mode. start mode momentarty position for starter motor. if i contine to hold key in start mode engine will run. really bad for starter. have replaced ignition switch. still have same issue. any thoughts would be great. thanks.  1985 searay 390. 454 gas engines
Edited by patdaddy on September 01 2008 at 11:01
pat
Back to Top Printable version View patdaddy's Profile Search for other posts by patdaddy
RCTII
Posted: September 01 2008 at 11:06 | IP Logged Quote RCTII
Patdaddy-
I had the same problem. Kill switch was on. Got a couple of laughs from by-standers.
RCTII
Back to Top Printable version View RCTII's Profile Search for other posts by RCTII
patdaddy
Posted: September 01 2008 at 11:19 | IP Logged Quote patdaddy
thanks for reply. kill switch is in run position other wise engine won't crank.
pat
AllenJ
Posted: September 01 2008 at 21:33 | IP Logged Quote AllenJ
Don't know how true this is for marine engines, but on an automotive engine there is a ballast resistor which, as I recall, shunts power to the starter depending on switch position. If it fails it will cause the symptoms described - the engine will start and run in the start position but not in the run position. Learned this one the hard way.
AllenJ
Back to Top Printable version View AllenJ's Profile Search for other posts by AllenJ
patdaddy
Posted: September 01 2008 at 23:23 | IP Logged Quote patdaddy
thanks for the reply. the resistor you speak of is mounted on the coil.
pat
midway
Posted: September 02 2008 at 10:05 | IP Logged Quote midway
It could be that the switch is not making contact on the ignition terminal, but is still working on all other places.
1994 GMC K1500 2004 Sea Ray 185 Sport 4.3L Alpha I
Back to Top Printable version View midway's Profile Search for other posts by midway
This page was generated in 0.8555 seconds.
