Seaswirl
 BoatUS Boat Groups/Manufacturer Forums>>Seaswirl
Subject Topic: taking on water while docked Post ReplyPost New Topic
mvikes
Posted: August 28 2008 at 17:34 | IP Logged Quote mvikes
Hi,
I own a 2005 seaswirl 2601 walkabout with the 5.7 ltr volvo penta motor. I seem to take on water while docked at port and don't know the reason why. Is it normal to tak on the water while docked?
mvikes
Back to Top Printable version View mvikes's Profile Search for other posts by mvikes
suwanneered
Posted: August 29 2008 at 16:59 | IP Logged Quote suwanneered
Hello: The boot on the out drive might be cracked and leaking. You might check that if it is leaking it will cause the gimbal bearing to go bad.Also check all thru hull fittings ,Good Luck,Bill
