Bayliner
Subject Topic: bayliner deck boat 197 a lemon? Post ReplyPost New Topic
sporty
Posted: August 16 2008 at 11:45 | IP Logged Quote sporty
Anyone else having similar problems? We picked up boat in spring of 2007. All during that year, randomly would click and not engage starter, but eventually would start. 2008 season, randomly will not start one weekend, then start the next. Had battery checked (good), replaced starter, started that day but now is back to clicking without starter turning over. I know of one other 197 owner that is having the same problem as mine from 2007. I am looking into returning boat using the Maine Lemon law.
Anyone know what the problem is and have a solution? Anyone experiencing same problem with same boat? I like the boat, but am going crazy with a problem we can't find a solution for.
thanks for your help
Edited by sporty on August 16 2008 at 11:47
Back to Top Printable version View sporty's Profile Search for other posts by sporty
bowrider1
Posted: August 16 2008 at 14:13 | IP Logged Quote bowrider1
check all your grounds for looseness and corrosion
check all your connections
1985 bayliner
capri 2150
bowrider
Back to Top Printable version View bowrider1's Profile Search for other posts by bowrider1
