Subject Topic: Ladder to Fly bridge Post ReplyPost New Topic
partgypsy
Posted: August 11 2008 at 15:46 | IP Logged Quote partgypsy
My 47 Chris is the cockpit version of the standard extended deck and as a result the, the deckhouse is about 6' shorter.
The ladder to the flybridge really uses up a lot of this valuable space. I
had the idea to make the ladder removable and open up the space a
bit. I expected the ladder to supply some vertical support to the
cabin top but I figured that the non-flybridge versions were fine
without a center support. I was quite surprised when the cabin top
dropped about 3/4 inch when the ladder was removed.
Is this something I should be concerned about or is that amount of
drop insignificant and possibly just due to old age or ?
Naturally the ladder will be put back in place whenever there is
occasion to be on the flybridge.
Back to Top Printable version View partgypsy's Profile Search for other posts by partgypsy
This page was generated in 0.9043 seconds.
