Bayliner
Subject Topic: Installing New Steering Rack and Cable Post ReplyPost New Topic
19bayliner
Posted: July 22 2008 at 23:24 | IP Logged Quote 19bayliner
19 Foot Run About - Mercruser I/O
It appears to be pretty difficult to pull the steering cable out through the factory installed hangers.  Probably even harder to fish the new cable back through from the helm to the transom.  Probably was hung there at the factory before the top of the hull was joined with the bottom hull.
Have any of you ever cut the factory hangers and dropped the cables out from under the inside  freeboard (gunwales)?  Then rigged new hangers?
Thanks for reading!
Edited by 19bayliner on July 22 2008 at 23:26
TDF
Back to Top Printable version View 19bayliner's Profile Search for other posts by 19bayliner
This page was generated in 0.9541 seconds.
