Subject Topic: Batteries Does it matter? Post ReplyPost New Topic
Tonymoree
Posted: July 13 2008 at 12:47 | IP Logged Quote Tonymoree
I have an inboard outboard merc, closed system. It does not have an alternator. My friend and I were told we should not run marine batteries because it could burn out the (I forgot what he called it ) charging mechinism. We were told to use a car battery? Any Thoughts on that anyone?
Tony Moree
Back to Top Printable version View Tonymoree's Profile Search for other posts by Tonymoree
Rock Hall
Posted: July 13 2008 at 20:53 | IP Logged Quote Rock Hall
Tony,
I'm a little confused. An I/O Mercruiser should have an alternator. The engine needs a battery to run and if it didnt have an alternator to charge the battery, it wouldnt run long. The alternator is what produces the current to charge the battery. It's really a generator that along with a voltage regulator produces around 14v to charge a 12v system.
Do you know anymore information on this?
Back to Top Printable version View Rock Hall's Profile Search for other posts by Rock Hall
Equinox
Posted: July 14 2008 at 14:58 | IP Logged Quote Equinox
Tony,
I think from your other post that you have the 4 cylinder mercruiser block.  The alternator is integral with the engine.  The stator and rotor is located behind the harmonic balancer.  The voltage regulator is located behind the exhaust manifold.  I have run marine batteries with no problem.
There are after market alternator kits to install an external alternator if yours fails.  The valtage regulator is expensive to repalce.  I think it was about $200 last time mine went.
This is not a typical marinzed automotive block.  You should get a shop manual.
Bob
Back to Top Printable version View Equinox's Profile Search for other posts by Equinox
Rock Hall
Posted: July 14 2008 at 16:08 | IP Logged Quote Rock Hall
Bob,
What years did they use this engine?
I’m interested in looking up some info on it.
Mark
Equinox
Posted: July 14 2008 at 16:38 | IP Logged Quote Equinox
Mark,
I'm not sure of the exact years.  I think it was 1976-1989.  They had a change where they changed the materials in the exhuast manifold from iron to aluminum.  It is also known as 3.7 liter.  You may want to Google for history of the engine/block.
Bob
This page was generated in 1.0625 seconds.
