![]](http://www.boatus.com/boatgroups/skins/azar/forum_images/left-side-table-bg.gif) |
| Author |
Capt. Heavy "First Mate"
| Posted: July 01 2008 at 13:13 | IP Logged
Here's something I don't believe I have ever discussed before. For those of you that have the old marine power model K engines that have remote oil filters, it it wise to keep an eye on the hoses that run from the oil filter (mounted on a bracket that bolts to the exhaust risers) to the adapter on the engine block. These hoses can become chaffed from engine vibration if they touch any thing. This will cause hose failure and total loss of oil pressure instantly. This is experiance talking. I spun a main bearing at 3000 rpm when an oil hose gave out. Rebuilt the engine, replaced oil hoses on both engines. Couple of years ago another hose failed, this time at idle, shut down engine, no damage. Replaced hoses again, this time with aircraft quality hoses with an outer protective jacket. What a mess 4 or 5 quarts of oil will make in the bilge. These remote filters make oil changes easy, but an ounce of prevention...! Capt Heavy
__________________ Capt. Steve, Stuart Fl. Chris Craft Owner- 25 catalina, 331 corinthian. Licensed Capt. 20 Years, Certified diver for 30 years. Avid fisherman.
Back to Top  |
OldNavy80 "Seaman Recruit"
| Posted: July 09 2008 at 13:40 | IP Logged
Wow thanks for the info, will defintely keep an eye on em
__________________ 1988 Chris Craft Amerosport 320 Staten Is, NY
Back to Top  |
![]](http://www.boatus.com/boatgroups/skins/azar/forum_images/right-side-table-bg.gif) |
If you wish to post a reply to this topic you must first login If you are not already registered you must first register
| You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
