Rinker
 BoatUS Boat Groups/Manufacturer Forums>>Rinker
Subject Topic: Water System Pump Post ReplyPost New Topic
sanjiv
Posted: June 09 2008 at 13:50 | IP Logged Quote sanjiv
I have a 2000 Rinker Fiesta Vee 270. The water in the faucet in the sink and shower comes only if the hose is attached to the water supply in the back of the boat, it does not come even with full tank otherwise. When I press the galley pump switch, nothing happens. I assume that the water pump is bad. My question is where is the pump? Is it in the area behind the steps on the wall or on the bottom in a box? What GPM pump to buy? How difficult is it to replace it? The round knobs below the steering wheel are for what? I am new to boating and the Rinker manual does not help much.  Thank you.
Sanjiv
Back to Top Printable version View sanjiv's Profile Search for other posts by sanjiv
