Subject Topic: ignition system 1878 281 Post ReplyPost New Topic
pelica11
Posted: May 23 2008 at 09:51 | IP Logged Quote pelica11
Hi fellow Chris Craft owners,
I have been having trouble with the port engin coil over heating and shorting out.  I was told it could be a bad ground, an faulty ignition switch or a short in the wiring somewhere.  I just bought a new coil no luck same out come.  I found a few questionable wires and sloppy connections no luck.  I had a few ignition switches tried them no luck.  I went and bought a new ignition swithch and bingo everything is right on spec.  My question is this the real fix or am I going to experience another electrical problem due to some unknown factor.
The Pelican
Owner of 1979 281 Catalina "The Emerald Lady" it's our get-away home.
Back to Top Printable version View pelica11's Profile Search for other posts by pelica11
This page was generated in 1.6094 seconds.
