Reinell
 BoatUS Boat Groups/Manufacturer Forums>>Reinell
Subject Topic: Engine Starting Issues Post ReplyPost New Topic
hmanso
Posted: May 06 2008 at 13:40 | IP Logged Quote hmanso
Hello all. i own a 1978 Reinell 1978 with a 140hp 4cyl mercury mercruiser engine. i have trouble starting it. the boat has power everywhere but the engine. it does not do anything at all. does anyone have any advise?
Back to Top Printable version View hmanso's Profile Search for other posts by hmanso
captbillc
Posted: May 06 2008 at 21:32 | IP Logged Quote captbillc
   from your question it seems the starter does not crank the engine at all. starter solenoids have a smaller wire connection which energizes the solenoid coil to activate the starter motor. when you turn the key to start you should have 12V at this terminal. if you do not, the trouble is in the key switch or wire. if this is the case you can start the engine by using a jumper wire from this terminal to the battery cable on the starter for an emergency start. if this will not work and you have 12V at the battery cable the solenoid or the starter is bad.       captain bill  captbillc@gmail.com       (retired diesel mechanic)
Back to Top Printable version View captbillc's Profile Search for other posts by captbillc
hmanso
Posted: May 07 2008 at 07:45 | IP Logged Quote hmanso
Captain Bill, thank you for the response. I will try the pointers you gave me i will let you know what happens.
hmanso
Posted: May 08 2008 at 23:25 | IP Logged Quote hmanso
captain bill, i did the jumper test and the starter did crank the engine. i did a test on the yellow red wire to test for the swicth but there was no power from there.
This page was generated in 1.7500 seconds.
