Subject Topic: GPS/Chartplotter with External Antenna Post ReplyPost New Topic
Vermit4
Posted: March 30 2008 at 17:31 | IP Logged Quote Vermit4
Hey all,
Have a 2004 Monticello that we purchaced last year and am looking at installing a flush mount/in dash  Lorwrance multifunction chartplotter. I would like to have the external antenna monted on the Radar arch. I am wondering if anyone has done this, and how difficult it is to run the cable thru the boat and up the arch?
 I am concerned that if I went with the internal antenna and the unit is flush mounted, I will not get the reception I am hoping for?
Thank in advance for your help!
Vermit4
Back to Top Printable version View Vermit4's Profile Search for other posts by Vermit4
Dravie
Posted: March 31 2008 at 08:18 | IP Logged Quote Dravie
Good day Vermit4,
It is not really difficult to run the cable:
1- you will install the antenna on the starboard side of the arch and will pass the cable through the same hole as the other cables came from the top
2- remove the side panel at the driver right side (screws that hold the panel in place are behind the gold or grey insertion)
3- fish the cable from the engine room through the bulkhead at the same place as the other harness and run the cable to the dashboard.
 Dravie
Back to Top Printable version View Dravie's Profile Search for other posts by Dravie
Vermit4
Posted: March 31 2008 at 19:08 | IP Logged Quote Vermit4
Thanks for your reply Dravie
I appreciate the tips, did'nt know about the drivers side panel. I take it I need to lower the arch to fish the cable thru to the engine room? I have not attempted that yet? But I guess it would be a good idea to experience it.
I will let you know how it goes.................. thanks again for your help!!
Vermit4
Dravie
Posted: April 01 2008 at 07:25 | IP Logged Quote Dravie
You are very welcome!
Dravie
This page was generated in 1.0781 seconds.
