Shamrock
 BoatUS Boat Groups/Manufacturer Forums>>Shamrock
Subject Topic: engine repowering Post ReplyPost New Topic
rogers
Posted: January 26 2008 at 10:43 | IP Logged Quote rogers
I have 1990 20 shamrock cuddy cabin.the 302 indmar raw water engine is junk. the boat is A-1. I am installing 5.7 crusader fresh water MPI.The water tank is over the rear. the engine will fit, however I can not determine what problems I might have reinstalling the batteries over the rear of the engine on the bracket arangement shamrock has on the 20 and what others, I don't know? any one with knowledge or exsperience with repowering and upgrading the indmar which is no longer used. I would not want to replace the indmar with another raw water carb. engine. I really want to use the crusader.
Back to Top Printable version View rogers's Profile Search for other posts by rogers
