Uniflite
Subject Topic: Should I bond my heat exchanger? Post ReplyPost New Topic
BoatRDavid
Posted: October 28 2007 at 16:37 | IP Logged Quote BoatRDavid
Hello All,
I have recently repaired one of my heat exchangers.  I will detail that project at another time, if anyone is interested.
In the process of repairing the exchanger (SenDure 3281-4-7) I was appling a coat of high temp paint and noticed that other than two shinny spots where it mounts to the engine (Detroit Diesel 8.2L), there is no electrical connection -- no bonding.  I was thinking of adding a wire to the system as is done on my sea water strainers, but then I thought about the fact that there was none originally.  Now I'm not sure what to do.  Should the heat exchanger be bonded?
David M. Oates
42 Uniflite SE II, Adventure
San Francisco Bay Area
Ron Dudas
Posted: October 29 2007 at 08:00 | IP Logged Quote Ron Dudas
Dave,  Since the heat exchanger is attached to the engine by the two matalic spots it should be automatically bonded to the engine.  Be sure that you haven't painted over these areas.  It's also a simple check with a ohm meter, to put your mind at ease check with the test leads from the heat exchanger to the engine, sea strainer, etc.
Ron Dudas
"Teena Maria" 42' Uniflite DC/MY
Back to Top Printable version View Ron Dudas's Profile Search for other posts by Ron Dudas
BoatRDavid
Posted: October 29 2007 at 13:28 | IP Logged Quote BoatRDavid
Thanks Ron,  I'll take that as a "yes".  I am not comfortable with the bear (paintless) spots on the mounting tabs, so I was going to include a bonding wire just to be sure, and since the exchanger is off and in my shop I can make that addition easily.
David M. Oates
This page was generated in 0.7656 seconds.
