Subject Topic: Identify water hose fittings help. Post ReplyPost New Topic
estame6
Posted: October 25 2007 at 12:17 | IP Logged Quote estame6
1988 30 foot Sea Ray. Need to replace water connection between a cold water tee to the hot water heater. Approx 12 inches long with fittings no one can identifiy including our local Sea ay dealer. All other similar Sea Rays in the club has same fittings. Is there a supplier anywhere that I can check with? Thanks.
Estame6
Back to Top Printable version View estame6's Profile Search for other posts by estame6
estame6
Posted: October 27 2007 at 16:59 | IP Logged Quote estame6
I thought with the number of 30 foot Sea Ray's around that were built
in the 80's someone would know of a supply. To start replacing all my
fittings because I can't find one compression fitting seems futile.
Maybe someone reading this and had froze a pipe or two and has a
suggestion.
Many thanks...
Estame6
