Pursuit
Subject Topic: Adding 2nd Bilge Pump to 2870WA Post ReplyPost New Topic
lazydawg
Posted: October 08 2007 at 15:55 | IP Logged Quote lazydawg
Anyone added a second bilge pump that would be closer to the bow? And if so, where did you locate it and how was it plumbed?
LD
Back to Top Printable version View lazydawg's Profile Search for other posts by lazydawg
yknot fishing
Posted: October 16 2007 at 21:50 | IP Logged Quote yknot fishing
I have the 2870 offshore with a sink in the cabin. I replaced the 500 gph pump with a 1500 and used the same float switch and overboard hose, fitting. I took the well that the sink drained into and place it on the bottom floor.  should work very well since I never use my sink and even if I did it would drain into the bilge
1996 2870 twin yamaha 200 hpdi Y-Knot
Wilmington NC
Back to Top Printable version View yknot fishing's Profile Search for other posts by yknot fishing
