| Posted: September 24 2007 at 19:39 | IP Logged
If you proved that the new guage works off the other motor by switching the wires at the sensor, then you have also proved that the sensor is bad.
If you switched the wires at the helm station, then it could be the sensor or the wiring.
To prove it is the sensor, just switch the sensors around. I have purchased defective new parts, so yes the "new" sensor could be bad.
Of course if you have a multi meter, just check the ohms resistance across the sensor as the temp rises.
Gary
Edited by gbarger on September 24 2007 at 19:40
