Trophy
 BoatUS Boat Groups/Manufacturer Forums>>Trophy
Subject Topic: TROPHY 2352 2005 Post ReplyPost New Topic
CARL2848
Posted: September 20 2007 at 12:02 | IP Logged Quote CARL2848
I HAVE TWO FISH BOXES IN THE DECK THAT CAME WITH THE BOAT. THEY TAKE ON WATER ALOT, IS THERE ANYTHING I CAN SEAL THEM WITH? I HAVE TRIED SELF STICK TYPE RUBBER AND IT DOESN'T LAST. ANY IDEAS?
Back to Top Printable version View CARL2848's Profile Search for other posts by CARL2848
Calm_C's
Posted: September 20 2007 at 17:33 | IP Logged Quote Calm_C's
Carl:
I have a 2503 with an ice tub built in the the transom with the same problem. Tried everything on the hatch with no luck.
I drilled a hole in the bottom and inserted a nipple attached a tube and ran it into one of the deck drain tubes. Since yours a deck mounted boxes, you might want to just let them drain int the bilge.
Back to Top Printable version View Calm_C's's Profile Search for other posts by Calm_C's
CARL2848
Posted: February 25 2010 at 05:54 | IP Logged Quote CARL2848
 I FINALLY FOUND SOMETHING THAT WORKS FOR THE FISH BOXES THAT FILL UP. TROPHY NOW WILL SEEL YOU THE RUBBER THAT GOES AROUND THE ENTRANCE WAY. TAKE THAT AND APPLY TO THE WELL. MY BOXES ARE DOING GOOD NOW. IT PAYS TO GO TO THE BOAT SHOWS AND SEE THE NEWER MODELS AND WHAT THEY HAVE DONE TO CORRECT SMALL PROBLEMS.
