Subject Topic: Maximum horsepower question Post ReplyPost New Topic
pare1
Posted: August 28 2007 at 20:53 | IP Logged Quote pare1
I just bought a 1988 Sea Ray Sundancer 268. My insurance application wants to know the maximum horsepower and I have no idea where to get this info. HELP PLEASE!
Thank you in advance.
PARE1
Edited by pare1 on August 28 2007 at 20:54
Back to Top Printable version View pare1's Profile Search for other posts by pare1
Jeff Evans
Posted: August 28 2007 at 20:58 | IP Logged Quote Jeff Evans
Typically maximum horsepower ratings refers to an outboard powered boat not an I/O.  The insurer wants to make sure you did not overpower the boat.
The largest engine I believe that is available for the 268 is a Mercruiser 454 (GM)which would put out 350-360 HP.
Regards,
Jeff Evans
Regards,
Jeff Evans
"4EVANSache"
1983 355 AC
Goderich, Ontario
Back to Top Printable version View Jeff Evans's Profile Search for other posts by Jeff Evans
dpmulvey
Posted: August 29 2007 at 07:12 | IP Logged Quote dpmulvey
Maximum HP is on the data plate on the boat.  It should be near the helm.  It refers to the maximum HP that can be safely applied to the structure.  Sea Ray should have the answer if you can't locate the data plate.  The insurance company will also want to know the HP of your engine.  If it is stock, you will be well within specs.
Regards,
David
330 Sundancer / 6.2 Mercruisers
Back to Top Printable version View dpmulvey's Profile Search for other posts by dpmulvey
This page was generated in 1.7339 seconds.
