Bayliner
Subject Topic: 1988 Bayliner Capri 19ft 1in Fuse Panel Post ReplyPost New Topic
BennettOZ
Posted: July 31 2007 at 12:39 | IP Logged Quote BennettOZ
Hi, We just purchased a 1988 Bayliner Capri which is open bow 19ft 1in. We bought the boat took it home and there are a few things that we cant seem to get to work. The front navigation lights and the rear light dont work. The Horn didn't work either, but I moved some fuses around and got the horn to work, but even with moving fuses around I still cant seem to get the lights to work. I located the fuse panel and noticed there was two fuses that had been burned.
If anyone has a diagram or can label a picture for me for which slot goes with what fuse and what fuse type belongs in each slot would be very helpful.
Here is an image of our fuse panel. (right hand side is facing bow of boat)
Thanks,
Edited by BennettOZ on July 31 2007 at 12:39
-BennettOZ
Back to Top Printable version View BennettOZ's Profile Search for other posts by BennettOZ
Outlaw
Posted: August 01 2007 at 19:29 | IP Logged Quote Outlaw
1st and 3rd fuse holder has wires connected but no fuses. did you try fuses in these? also last two fuse holders have no wires connected but have fuses in these. are there loose wires that need to go to these fuses?
Every day on the water is a good day
Back to Top Printable version View Outlaw's Profile Search for other posts by Outlaw
