Subject Topic: LEAKING FUEL TANK !! Post ReplyPost New Topic
Dlavington
Posted: July 13 2007 at 10:31 | IP Logged Quote Dlavington
HELP !!  I HAVE A HOLE IN THE BOTTOM OF MY FUEL TANK, AND THE YARD WHERE THE BOAT WAS HAULED (KINGMAN, IN CATAUMET MASS) THINKS THE ONLY THING TO DO IS CUT THE TANK INTO PIECES TO REMOVE IT, AND THEN INSTALL TWO SMALL TANKS.
   THE BOAT IS A 1985 29 FT CATALINA, TWIN SCREW.  THE YARD ASSUMES THE TANK WAS INSTALLED BEFORE THE ENGINES, OR BEFORE THE DECK WAS ATTACHED; IT IS TOO BIG TO GET OUT OF THE EXISTING HATCH.
    SOUNDS REALLY EXPENSIVE, AND I WONDER IF ANYONE ELSE HAS HAD A SIMILAR PROBLEM AND COME UP WITH A FIX.
    DAVE 7/13 (FRIDAY THE 13TH!!)
HIGH HOPES, 1985 ChrisCraft Catalina, 29 ft fb cruiser
Back to Top Printable version View Dlavington's Profile Search for other posts by Dlavington
Pete37
Posted: July 13 2007 at 12:25 | IP Logged Quote Pete37
Hi Dave,
Unfortunately, leaky fuel tanks are a very common problem (particularly with aluminum tanks) and they are often installed in places that are nearly impossible to access after the boat is closed in.  It's expensive and there doesn't seem to be any magic solution.  I'm sure that there are others with the same problem but I doubt they have come up with a cheap fix.
Sorry, I can't come up with any good news,
Pete37
INTERLUDE
sdunlap20690
Posted: September 15 2007 at 10:45 | IP Logged Quote sdunlap20690
Dave,
The Uniflite forum had something about changing tanks a couple of years ago.  As I recall, the engine had to be removed on the side of the tank being removed.  It almost sounds like a "whilel you are at it" i.e. repower and oh by the way change the tanks.  The folks at Sea Cure Technologies (see links in CC forum) may have some insight.  They may also have the wiring diagrams you were looking for.  I bought a set from them for my 1986 362 Catalina.
Steve
Some Tuesday
Tall Timbers MD
Steve and Pat
Some Tuesday
1986 362
Tall Timbers MD
Back to Top Printable version View sdunlap20690's Profile Search for other posts by sdunlap20690
Dlavington
Posted: September 17 2007 at 11:41 | IP Logged Quote Dlavington
Thanks for the suggestions.  I've replaced the gas tank.  The best solution seemed to be to chop up the old tank, and replace it with two smaller tanks that fit in through the existing hatch, so that's what I had done.  I now have two 60-gallon tanks instead of one 125; not a bad switch.
I've emailed SeaCure about a wiring diagram, but haven't heard back yet.
Dave
