Subject Topic: Standing water Post ReplyPost New Topic
Banjoman
"First Mate"
Posted: July 02 2007 at 20:31 | IP Logged Quote Banjoman
A common problem on the 500's is standing water on the decks abaft the saloon windows.  Have any of you folks come up with a solution?  I am considering install scuppers and routing the water to a thru-hull above the existing overboards.  Is there a simpler solution?
Capt. G. Emory Shover
m/v "SOUTHERN CHARM"
Eastern Marine Services, LLC
www.easternmarineservices.com
Pete37
Posted: July 13 2007 at 00:59 | IP Logged Quote Pete37
Hi Again Banjoman,
Yes, the standing water problem has been discussed at length on the Murray Chris Craft Constellation 500 forum and several solutions found.  Furman1 seems to have the best solution.  Be very careful because the the decks are cored and if you let water into the core you will have major problems.
Pete37
INTERLUDE
This page was generated in 0.9824 seconds.
