Trojan
Subject Topic: Ricks Rehab Finished Post ReplyPost New Topic
Rick1954
Posted: June 29 2007 at 10:28 | IP Logged Quote Rick1954
Well every one, I hope you all are enjoying the season , and are having a wonderful time. I have finished everything that I wanted to do, my little Trojan is now better than that of the manufacturer. I have several teak decks to install now along with manufacturing swim platforms, lighting systems, refrigeration, air-conditioning, etc. I think I have started a bright-works business without trying.
She came out very nice, we changed her name from White Whale to Sea- Scape, we didn’t do the changing of the name ceremony to parsidon and almost sunk her at the dock. I had switched over to a battery that was not up to snuff, I didn’t put on the charger, I left my search Light on (could not see it, didn’t know it was on) sprung a leak in the stern thru an old 8/32 screw hole that was not repaired properly ( I am not saying whom did that )  the light killed the battery, pump could not pump out the water well!! 10" of water in the bottom of the boat, she is clean now.
Needless to say, several other boaters had problems that night, so when I arrived at the marina that morning I was met with bottle in hand and the name was changed proper, no more problems, what can I say
RSM
Coralkong
Posted: July 06 2007 at 07:22 | IP Logged Quote Coralkong
Glad to see you made it!
This page was generated in 0.8418 seconds.
