Subject Topic: fuel gauge not working Post ReplyPost New Topic
GeorgiaBuddy
Posted: June 09 2007 at 08:02 | IP Logged Quote GeorgiaBuddy
I have a '99 300SE. I recently filled my fuel tank. Prior to that my fuel gauge worked perfectly. Immediately after filling the tank, I noticed the gauge remained on empty. It has remained on empty. Any suggestions on how to diagnose and correct this problem?
Thank you.
Edited by GeorgiaBuddy on June 13 2007 at 21:54
Back to Top Printable version View GeorgiaBuddy's Profile Search for other posts by GeorgiaBuddy
rasberry
Posted: June 19 2007 at 15:27 | IP Logged Quote rasberry
Sounds like your ground wire came loss.
Check and make sure it is still connected. If it is ok, check you hot wire and make sure it is getting a good connection.
Back to Top Printable version View rasberry's Profile Search for other posts by rasberry
This page was generated in 1.4531 seconds.
