Subject Topic: Trim Tabs Post ReplyPost New Topic
Lizzy
Posted: June 03 2007 at 20:53 | IP Logged Quote Lizzy
having just received my 250SE from winter storage i notice that after using the trim tabs there was an apparent oil leakage from the trim tab reservoir into the water
the oil reservoir was almost empty and on contacting the boat yard i was informed that this was a fairly common problem as muskrats could possibly have gnawed through the external oil pipes.
as this also happened last year and it was rectified by the boat yard replacing the relevant parts is there any permanent action that can be taken to stop this happening in future.
any other ideas of what could cause the problem would also be appreciated
Back to Top Printable version View Lizzy's Profile Search for other posts by Lizzy
NHDoral
Posted: June 04 2007 at 10:41 | IP Logged Quote NHDoral
I have a few customers who put steel covers over the lines. YOu can buy them at an auozone and they just ziptie on.
Good Luck!
Back to Top Printable version View NHDoral's Profile Search for other posts by NHDoral Visit NHDoral's Homepage
