Subject Topic: Pressure Pump trip Switch Post ReplyPost New Topic
Keith Aquaholic
Posted: May 22 2007 at 04:31 | IP Logged Quote Keith Aquaholic
Hi everyone in the forum  just took delivery of an 05 Prestancia and am having a few teething problems. I am a litttle concerned as the 2 year warranty runs out at the end of this month. I took delivery after it had the 100 hour service and the Engineers said everything was perfect. I have used the boat twice now and have had the same problem with the extended seat moving while underway nearly lost the wife. the pressure pump trip switch just started tripping this weekend and will not set, and the portside engine bay  fills up with Salt water. I hope these are all teething problems. The portside Engine bay is my main concern. I hope it is just a loose pipe from when they did the 100 hour service last month.. One more thing I used the windlass anchor when we stopped for a spot of Fishing.  Could not get the Anchor back up. I thought the Windlass motor was ceased..  While looking around at the motor i noticed a thin black wire cut in half.  Twisted it back together reset the trip switch in the engine bay. hay presto works. What a relief. So if you have the quick windlass stick your hand under and make sure that the little black wire is well away from the chain.
Doral Prestancia 2005
Back to Top Printable version View Keith Aquaholic's Profile Search for other posts by Keith Aquaholic
shepdog
Posted: May 22 2007 at 10:49 | IP Logged Quote shepdog
First...you need to check your raw water intake immediately. That is
the likely cause of "salt" water intrusion. If that hose is not properly
clamped it will spew raw water into your engine compartment. Get
that fixed immediately and also make sure to clean up anything it
may have sprayed with an anti-corrosive cleaner to avoid some
future problems.
Second, on that seat you need to make sure the latch catches
properly. Ours gave like that a couple of times, but I always felt it
was because we hadn't checked to see that it had latched properly
after we had it extended earlier. Each time you get under way give
that seat a "pull" and then look underneath at that latch to make sure
it is secure.
Finally, on your windlass, make sure you've properly clamped those
wires and protected them from corrosion or you'll be having that
problem on a regular basis...
Shep
Not totally boatless...I kept the dinghy!
Back to Top Printable version View shepdog's Profile Search for other posts by shepdog
three of a kind
Posted: May 22 2007 at 11:10 | IP Logged Quote three of a kind
Keith
We had similar problem with the seat on our 04 Prestancia....we had the latch replaced twice - didnt work, kept sliding out.  Finally we had two pegs installed the drill through the plastic overlap thingy into the fixed portion of the seat.  If you want i can try and post a picture.
So far i still i have my wife and kids.
Rich
Back to Top Printable version View three of a kind's Profile Search for other posts by three of a kind
Keith Aquaholic
Posted: May 24 2007 at 11:49 | IP Logged Quote Keith Aquaholic
Thanks for the feed back, will check the sea water intake tomorrow, and will spray everything that the water level has reached. If that fails will lift it out and let the engineers sort the problem.. I need the Starboard side gear cable changing anyway because it has become very stiff.  Note the comments on the Seat. Doral told me to lubricate it. Cant see how that will work but will give it a try. If Rich could send me those pics I would it would be mutch appreciated.
Regards
Keith
Keith Aquaholic
Posted: May 30 2007 at 06:30 | IP Logged Quote Keith Aquaholic
Found the problem with the pressure pump Trip Switch..  Pump was faulty.. Tested it using a sperate jump start 12v battery. Pump connector just sparked. Swapped pump. Works fine..
