Four Winns
 BoatUS Boat Groups/Manufacturer Forums>>Four Winns
Subject Topic: 205 Sundowner Deck Drains (Scuppers) Post ReplyPost New Topic
rabbar
Posted: May 20 2007 at 10:29 | IP Logged Quote rabbar
I have a 2002 Four Winns 205 Sundowner.  Bought the boat new in 2003.  Have had numerous problems with this model.  To many to list here!!!   The most recent issue is with the deck drains (scuppers) in the stern of the boat behind the battery (starboard side) and trim pump (port side).
These deck drains are supposed to allow any water that manages to get into the boat drain out thru some below the waterline hull fittings.  Yeah right!!!  These scuppers, or deck drains if you will, allow water to seep back into the boat when enough weight (people) is on the stern of the boat.  This boat has the extended swim platform so having 3 or 4 adults sitting back there is not uncommon.  In the scuppers are check valves (floating ball the size of ping pong ball) that are supposed to seal off the flow of water back into the boat (backflow) from the drains located near the outdrive below the waterline.  The deck drains are at or near waterline level.
Has anyone else out there been having this problem?  If so has anyone come up with a good way to seal off these drains?  I really don't think they are needed on a boat of this type and size.
Edited by rabbar on September 13 2007 at 20:23
Back to Top Printable version View rabbar's Profile Search for other posts by rabbar
wkearney99
Posted: May 20 2007 at 11:22 | IP Logged Quote wkearney99
Have you contacted Four Winns about it?
You might also try asking on the www.ifourwinns.com/forum website.
2005 Four Winns 348 Vista
Back to Top Printable version View wkearney99's Profile Search for other posts by wkearney99
rabbar
Posted: May 20 2007 at 17:45 | IP Logged Quote rabbar
Yeah, I have spent a lot of time contacting Four Winns the past 4 years.  For the most part they have fixed the on going problems but this boat is still a lemon.  I have offered to sell it back to them both verbally and in writing.  They haven't sent me a check yet.  It's a long story.
rabbar
Posted: May 30 2007 at 07:48 | IP Logged Quote rabbar
UPDATE.  Decided to check the condition of the floating ping pong balls based on replies I got thru a post on iFourwinns.com. Not an easy task on this 2002 205. Had to remove the engine cover, rear seat back, rear bulk head, battery and battery tray, and hydraulic trim tab pump to gain access to the deck drains. Glad I am not a boat mechanic!!! Removed the drain cover and ping pong ball on starboard side. Visual inspection revealed the cover of the drain is warped so that the ball does not seal 100% against the lip it contacts when it floats. Rather than replace the drain we have sealed them at both ends with silicone.  This has been the best solution to the problem.  No more water in the boat all summer seeping in from the drains.
Edited by rabbar on October 05 2007 at 06:15
marine007
Posted: July 18 2007 at 16:14 | IP Logged Quote marine007
I currently own a 2005 348 Vista Four Winns boat and I have had several problems with this it, gauges, and serveral other issues, has anyone seen these similar problems on this year and model boat?
Back to Top Printable version View marine007's Profile Search for other posts by marine007
