Subject Topic: need Some Help! Post ReplyPost New Topic
Lappin1979
Posted: April 13 2007 at 12:53 | IP Logged Quote Lappin1979
The boat in question is a Seamaster 20' from year 2000. but there are no seamaster links on this forum. So I assume that seamaster is not a manufactuer. So any suggestion on how to figure out the real manufacturer would be appreciated.
2nd. I believe the gas tank on this 20' cracked due to water freezing around it. Are there any links to stainless steel gas tank manufactuerers? OR should I just go the route of self repair with spot welding?
Thanks in advance
Back to Top Printable version View Lappin1979's Profile Search for other posts by Lappin1979
midway
Posted: April 13 2007 at 14:10 | IP Logged Quote midway
Don't know if this will help on not, it is Apache/ Seamaster  boats.
http://www.deckboat.com/boats/default.asp
1994 GMC K1500 2004 Sea Ray 185 Sport 4.3L Alpha I
Back to Top Printable version View midway's Profile Search for other posts by midway
