| Posted: April 24 2007 at 22:53 | IP Logged
Bill -
I had the same problem, my windlas wasn't set directly over the locker and it used to bind the same way going in and out. I took off the Goode windlass and put on the following so the rode would pull out clean and set back in the locker without binding:
I bought a PVC shower drain (2x3") with stainless strainer, drilled out the center of the strainer to the size of the hole in my deck, drilled out the screw holes in the PVC portion so I could get SS nuts/bolts long enough to reach and mounted all this under the windlass - SS on top of the deck and PVC in the locker. I reduced the 2x3 shower drain to 1.5" and added 2 45's to dump the rode in the middle of the locker.
I understand this is confusing, but gives you a gist of what I did. Scott
