Marathon Boats
 BoatUS Boat Groups/Manufacturer Forums>>Marathon Boats
Subject Topic: info for marathon 2350 Post ReplyPost New Topic
northcoast
Posted: February 26 2007 at 16:06 | IP Logged Quote northcoast
I have a 1986-87 Marathon 2350. I think it is the Sunblazer. It has a omc-GM 5 liter with a Volvo Cobra outdrive.
I would like any printed info even ads or brochures.
It has been a great boat except for the neutral switch if tempermental. Any advice would be apprieciated.
Back to Top Printable version View northcoast's Profile Search for other posts by northcoast
TerryJ
Posted: July 09 2008 at 17:54 | IP Logged Quote TerryJ
 Go to the iboats.com website, look under boat manufacturers, where you will see Marathon , then under that you will see Marathon Cruisers, next to last you will see Marathon Cruisers Sunblazer, lastly you will see Marathon Cruisers 2350 Sunblazer Years!!  If you have trouble finding it, just type in the address bar: http://www.iboats.com/b/ then look for MARATHON CRUISERS.
Edited by TerryJ on July 22 2008 at 12:46
Back to Top Printable version View TerryJ's Profile Search for other posts by TerryJ
Bob David
Posted: July 10 2008 at 00:59 | IP Logged Quote Bob David
northcoast, I'd like to invite you to join the discussion group on the forum that is exclusively Marathon owners. Most of use have the cuddy cabins as mine is a Marathon 2150 weekender. There are a couple of 2550's and I do believe that there may be one 2350 in the bunch. Great old boats.
As far as your gear problem, one other member had the same problem with a Penta drive. I helped research  the problem for him and found it to be with the Penta drive Itself moreso than the Mercruiser out drives. He had to rebuild his shifting mechanism. You may be able to get with him and find out what his answer may be.
Bob
Back to Top Printable version View Bob David's Profile Search for other posts by Bob David
TerryJ
Posted: July 22 2008 at 12:43 | IP Logged Quote TerryJ
Hello again,
I just came across a website that can give you a little more information about the stern drive on your Marathon Boat! The web address is
http:marinemechanic.com. Once you are there, click on the home page that uses frames if that is your preference. Then click on home at the top of the very left hand column. This gets you into the actual website. Now look on the right hand side and scroll down till you see the engines section( it will be the third one down)click on it and you will be at the Propulsion Page. Now about one page down you will see OMC Reference Guide. Click on this and it will bring a diagram that explains the code on your engine. I hope this helps!!!
                 Terry
Edited by TerryJ on July 22 2008 at 12:45
Norm_Richards
Posted: December 05 2008 at 21:54 | IP Logged Quote Norm_Richards
Hello and Attention all Marathon Boat Owners:
Please join us on the main Marathon Boat Owners forum on site:
http://my.boatus.com/forum/forum_posts.asp?TID=62706&PN= 1
Norm
Marathon Owner
Toronto, Ontario, Canada
Norm Richards
Marathon Boat Owners Group - Member #7 - VINTAGE HAVEN
Back to Top Printable version View Norm_Richards's Profile Search for other posts by Norm_Richards
This page was generated in 1.8130 seconds.
