Subject Topic: 1983 SeaRay 36’ aft cabin, gas mileage Post ReplyPost New Topic
stroiani
Posted: February 19 2007 at 17:16 | IP Logged Quote stroiani
We have a 1983 SeaRay 36' Aft cabin.  It has two 260hp Mercruisers.  Does anyone have any idea how many miles per gallon this boat will get.  We are trying to figure out how much fuel we need to go a specific distance.  It holds 270 gallons.  Also, we have Onan generator, 6.5, any ideas on how much gas it uses per hour?  Has anyone repowered this boat with new motors and with labor does anyone have an idea what the cost is?  We are new boat owners and have no idea.
Thanks, John and Sharon
SeaRay 36' aft cabin 1983
Back to Top Printable version View stroiani's Profile Search for other posts by stroiani
Jeff Evans
Posted: February 24 2007 at 08:08 | IP Logged Quote Jeff Evans
Hello John and Sharon,
I have the same boat with Crusader 454s (350 HP) engines.  Off plane at about 7 knots we get 1 US mile/gallon.  On plane at 17 knots we get about 0.7 miles per gallon.
We installed Floscan fuel flow meters and charted the fuel consumption from 600 - 4000 rpm.  With the 360 (355) AC's hull, there is no "sweet spot".  The faster you go, the worse the mileage.
Given the cost of fuel, we operate the boat as a trawler and rarely put it on plane.  I hope this helps.
This winter we pulled the intake manifold on the port engine and found the engine in excellent condition after 1600 hours.  Repowering is extemely expensive and difficult on this boat so I would make sure it must be done before proceeding.  Instead, we updated the ignition system and rebuilt the carbs to get the best fuel milage possible.
Regards,
Jeff Evans
Regards,
Jeff Evans
"4EVANSache"
1983 355 AC
Goderich, Ontario
Back to Top Printable version View Jeff Evans's Profile Search for other posts by Jeff Evans
stroiani
Posted: February 26 2007 at 01:01 | IP Logged Quote stroiani
Jeff,
Thanks so much for your information.  We had a mechanic-a trusted friend-check our motors and one of the cylinders is not firing.  The boat has less than 1900 hours on it and we were told it had 336 hours since the motors were rebuilt when we purchased it.  Our mechanic thinks that is not correct since the boat had 1686 when we purchased it.  We have put less than 200 hours on it and with the 336 should only be 530 hours since the engines were rebuilt.  They are tired and quite a bit slower than when we purchased it.  They would top out at 20-21 when purchased and now we can barely get them to 15.  How difficult and expensive is the Floscan meter to install?
Thanks,
John and Sharon
stroiani
Posted: February 26 2007 at 18:54 | IP Logged Quote stroiani
Jeff,
Our motors are not fuel injected-are yours?  We burn about a quart of oil every 1/2 tank of gas, our tanks hold 270 gallons.  Do you use any oil as this?  What did you do to upgrade your ignition system?  Our is electronic ignition, is yours?  Since the boat had several previous owners, none of which we knew, we dont have much info to go on.  Our mechanic friend did a compression check and one cylinder has 0 compression.   Cant tell more until the heads are removed so we are not quite sure what to do.  Do you have a closed system?
Thanks,
John & Sharon
Jeff Evans
Posted: February 27 2007 at 08:36 | IP Logged Quote Jeff Evans
You had a few questions which I will try to answer.  Feel free to ask further and I will respond if possible.
Question: " How difficult and expensive is the Floscan meter to install?"
I believe a twin engine (gas, non- fuel injected) is about $400 US.  Plan for another $50 for cabling and misc bits.  Installation is not difficult (2-3 hours) but as you are cutting into the fuel lines, you want to make sure you plan your work to not have fuel leaks.  I put the gauge on the flybridge and rebuilt the panel for the new gauge (photo attached).
Question: "Our motors are not fuel injected-are yours?"
Mine are carbourated as well.  Rochester Quadrajets.
Question: "Do you use any oil as this?"
I may use 1 quart of oil for each engine in one season (100 hours).  As you have found, your engine has a serious problem.
Question: "What did you do to upgrade your ignition system?"
The ignition is a traditional point system (not electronic).  Suprisingly, one engine has a Mallory distributor and one a Prestolite.  We installed a simple kit from Sierra on the Presolite distributor that replaces the points and condenser.  It cost aout $100 US and works very well.  We will modify the Mallory distributor this spring.
Question: "Do you have a closed system?"
No.  Being on the Great Lakes, I get away with having raw water cooling.
Here are some pictures of the dash after installing the Floscan.
Regards,
Jeff Evans
"4EVANSache"
1983 355 AC
Goderich, Ontario
Jeff Evans
Posted: February 27 2007 at 08:46 | IP Logged Quote Jeff Evans
In case you do not have it already, you can download the owner's manual for your boat at:
http://www.searay.com/owners_manuals.asp?tab=&year=1983& amp;folder2=83_355_Aft_Cabin
Regards,
Jeff Evans
"4EVANSache"
1983 355 AC
Goderich, Ontario
stroiani
Posted: February 28 2007 at 20:15 | IP Logged Quote stroiani
Jeff,
Thanks so much for the manual.  we have an old, been wet, parts missing one with the boat.  We have emailed several boat yards to try and get a ballpark idea on how much and what is entailed to repower or rebuild.  Not quite sure what is best at this point.  Thanks for the pix and answering all our questions.  Your flybridge looks exactly like ours except our is navy blue.
Have a safe and fun summer!
This page was generated in 1.3594 seconds.
