Subject Topic: 2001 Sundancer problem Post ReplyPost New Topic
josheafl
Posted: January 21 2007 at 19:51 | IP Logged Quote josheafl
The hatch doors for the battery compartment and the cooler compartment underneath the top side sink/wetbar are losing their powder coat. It is not actually the door itself as this is platic, but rather the the metal rimming of the door. I tried to take it out to replace but it won't budge.
Anyone else have similar issues? Any way to get these out and order a replacement part?
It looks terrible the way it is....
Back to Top Printable version View josheafl's Profile Search for other posts by josheafl
fwebster
Posted: January 23 2007 at 09:24 | IP Logged Quote fwebster
Cockpit door frames are extremely well caulked. You will need to insert a razor knife in the joint between the aluminum and fiberglass and cut the caulking.....probably on both sides, the nvery gently work the frame out.
They can be replaces, but it may be more cost effective to have them repainted by a shop than knows how to prepare, prime and paint aluminum. Or you can do it yourself.
Whether you repaint or replace, understand that the cause of the corrosion is stainless steel screws in an aluminum frame. When you reinstall the frame, be sure you fully caulk the screws as they are inserted.
FWebster
Back to Top Printable version View fwebster's Profile Search for other posts by fwebster
davefin
Posted: May 29 2007 at 21:39 | IP Logged Quote davefin
I had the same problem on my 2001 310DA.  I purchased new in 2001 and the corrosion started in 2004.  I heard that there was a manufacturing issue with these moldings, so I contacted SeaRay.  They asked for a couple of pictures.  To make this short, they sent replacement moldings to my local MarineMax and they installed for FREE.  That's how I like it.
SeaRay 310DAChrissie B 2"Always remember, you are unique, just like everyone else"
Back to Top Printable version View davefin's Profile Search for other posts by davefin
~*Caroline*~
Posted: August 09 2007 at 11:58 | IP Logged Quote ~*Caroline*~
Yeah Usually if they know they have a problem like this that happened on alot of boats, they will usually replace the parts for free. I would contact Sea Ray or either your dealer and tell him to contact Sea Ray about replacing the parts. Tell them you have heard of other people who the same thing happened.
Back to Top Printable version View ~*Caroline*~'s Profile Search for other posts by ~*Caroline*~
This page was generated in 1.8125 seconds.
