Posted: Today at: 21:52
Albin
 BoatUS Boat Groups/Manufacturer Forums>>Albin
Subject Topic: albin 32 sportsfisher questions Post ReplyPost New Topic
leeg427
Posted: January 15 2007 at 00:02 | IP Logged Quote leeg427
Am looking hard at a 32 Albin Sportsfisher 1989. The second owners had the bottom "redone" 3 years ago and patches of blisters were hand ground off and epoxy treated.  The hull has been repainted and a new V drive fitted. She has a 250 hp Cummings original engine with about 6oo hr on it.  The deck apparently has considerable gel coat degredation (crazing). The interior has been completely redone and is well sorted out.
Questions:  They want $79,000 --Reasonable? given the bottom blistering?
I live in Hawaii and we usually have 4-6ft seas AT A MINIMUM in the channels between the islands. Can anyone give me a sense of how safe a single engine diesel Albin will be for Hawaiian waters.  I currently run an 18 Ft Whaler Montauk over to Molokai but have 2 engines.
Has anyone put a medium sized fighting chair in one of these boats and will the cockpit deck need to be reinforced or not?
Where are these boats made and is the hull on this year/model full glass or is there a foam and or balsa core I need to worry about?
Thank you for any information -------------   Lee G
LEE G
Back to Top Printable version View leeg427's Profile Search for other posts by leeg427
daisydog7
Posted: March 08 2007 at 19:42 | IP Logged Quote daisydog7
   Did you buy the Albin 32 Sportsfisher?  We are looking at the same year and model as yours.  Can you tell us the cruising speed and top speed of your Albin 32 Sportsfisher?  Thanks for any info. Pam
Back to Top Printable version View daisydog7's Profile Search for other posts by daisydog7
JPRohan
Posted: April 06 2008 at 10:25 | IP Logged Quote JPRohan
JPRohan
Back to Top Printable version View JPRohan's Profile Search for other posts by JPRohan
JPRohan
Posted: April 06 2008 at 10:27 | IP Logged Quote JPRohan
I have the same boat, bought new.  you will have to reinforce floor for the chair; the hull is glass, the topsides are cored...beware of water intrusion around the rod holders.   I never had a blister problem...the albin will handle the seas just fine; but the 250 HP will make it a 10-12 knot boat.  It'll bearly plane.  I have the cummins 300 and it is a 16 knot boat.  I think 65 thou is a more reasonable figure.
JPRohan
JPRohan
Posted: April 06 2008 at 10:28 | IP Logged Quote JPRohan
JPRohan
Russell Sepsi
Posted: March 26 2009 at 12:23 | IP Logged Quote Russell Sepsi
R. R. Sepsi
Back to Top Printable version View Russell Sepsi's Profile Search for other posts by Russell Sepsi
PeninsularEngines
Posted: October 22 2009 at 11:54 | IP Logged Quote PeninsularEngines
If you need any information about your Peninsular Diesel engine in your Albin boat, don't hesitate to contact me at Bert@PeninsularDiesel.com
We're here to help you in any way we can.
www.PeninsularDiesel.com
Bert DeVries
Peninsular Engines, Inc.
Back to Top Printable version View PeninsularEngines's Profile Search for other posts by PeninsularEngines
This page was generated in 1.5000 seconds.
