Formula/Thunderbird
Subject Topic: 1977 233 Post ReplyPost New Topic
BEECHBM69
Posted: January 12 2007 at 13:32 | IP Logged Quote BEECHBM69
I am looking at buying a 77 F233. I suspect it has a fiberglass fuel tank,
but have not been able to verify that with the PO. Does anyone have
any info on the fuel tank in this time frame and whether or not it reacts
with ethanol? Most of what I have been reading is from Bertram owners
but have found nothing on Formulas. Thank you in advance for any
insight.
Dan
Back to Top Printable version View BEECHBM69's Profile Search for other posts by BEECHBM69
fshtalzF233C
Posted: January 27 2007 at 19:42 | IP Logged Quote fshtalzF233C
insight.
Dan
1977 F233C 5.7LX BravoIII
Back to Top Printable version View fshtalzF233C's Profile Search for other posts by fshtalzF233C
fshtalzF233C
Posted: January 27 2007 at 19:44 | IP Logged Quote fshtalzF233C
insight.
Dan
Every F-233 I've seen has been built with aluminum tanks. Age is a problem but not Ethanol.
gonefishing
Posted: January 29 2007 at 15:24 | IP Logged Quote gonefishing
my 80 233 built in 79 has aluminium no problems with ethanol, now our bertram was a different story. Ethanol totaled out the fuel system ,from tank to carbs to heads.
Back to Top Printable version View gonefishing's Profile Search for other posts by gonefishing
blystovski
Posted: May 08 2007 at 10:21 | IP Logged Quote blystovski
1976 Formula F-20, part of the restoration had the floor and flotation foam out from the rear 1/2 of the boat.  My tank is certainly aluminum, and I am sure it was the factory original.  I would be concerned about all of the other fittings etc., especially on these older boats - just my $0.02.  Good luck!
Back to Top Printable version View blystovski's Profile Search for other posts by blystovski
rpeter46
Posted: May 08 2007 at 20:06 | IP Logged Quote rpeter46
I have just begun a 1969 project Thunderbird Formula.  It has 2 aluminum gas tanks.  Should I be concerned about using gasoline with ethanol?  If so, what would I need to do to keep from having problems with that?
Back to Top Printable version View rpeter46's Profile Search for other posts by rpeter46
