Subject Topic: Changing seal in dripless through hull Post ReplyPost New Topic
djenkins
Posted: January 04 2007 at 15:04 | IP Logged Quote djenkins
Hello,
I'm being told that in order to change the seals on my shaft's dripless through hull on my '97 330 Sundancer that they must lift the engines out of the boat.  Is this true?  I know its a tight space, but is it possible for a mechanic to change the seals on the shaft's dripless without pulling out the engines????
Duane
Edited by djenkins on January 04 2007 at 15:05
Firefly - Sea Ray 330 Sundancer
Firefly's Photo Gallery
Back to Top Printable version View djenkins's Profile Search for other posts by djenkins
ssilb33
Posted: January 05 2007 at 11:03 | IP Logged Quote ssilb33
 Try clubsearay.com/
Back to Top Printable version View ssilb33's Profile Search for other posts by ssilb33
