Subject Topic: Heat Exchangers Post ReplyPost New Topic
Furman1
Posted: December 11 2006 at 20:41 | IP Logged Quote Furman1
I have Johnson & Towers DD 6-92s in my 1986 CC500. It has aluminum casings on the exchangers, these can be damaged by cavitation and need to be replaced. I have checked with J&T and they have the replacement in steel for 3.2 boat units each. (boat unit =$1000.00) Does anyone know of an aftermarket replacement or a cheaper source of replacements. This would be for the casing only, the cores should last forever (per J&T)  Mine are not bad now but I would like to have a source when (not if) they go bad.
I understand when they go bad it will be pin-hole leaks not a major failure again per J&T.
Remember...the nearest land is usually beneath the boat!
Furman
Back to Top Printable version View Furman1's Profile Search for other posts by Furman1
Pete37
Posted: December 12 2006 at 13:06 | IP Logged Quote Pete37
Hi Furman1,
Wow! That's a scary proposition.  I've never heard of cavitation in the heat exchanger although it often occurs in blocks.  I don't have an answer but perhaps someone on www.boatdiesel.com/HOME.htm might have an answer.  This site seems to be populated by diesel mechanics.
Pete37
INTERLUDE
