Carver
Subject Topic: Kholer 7.5 kw RECALL Post ReplyPost New Topic
Truitt
Posted: December 10 2006 at 23:54 | IP Logged Quote Truitt
I am taking possession of a 1987 32' Aft cabin (3207) next week in Va. and bring her home to Pamlico Sound, NC ( Pamlico River ). She has the original Kholer 7.5 Gen Set and have just been told there was a problem with the exhaust manifold leaking and could cause one to drift of into a very peaceful sleep, unfortunately, you don't wake up due to carbon monoxide poison. Is anyone aware of a recall of this generator and are there any precautions other than a detector in the sleeping quarters ?
I am new to this forum and would like to share ideas with you.
Truitt
Carver 1987 3207
PAMLICO SOUND, NC
truitt@earthlink.net
Back to Top Printable version View Truitt's Profile Search for other posts by Truitt
Jerry92746
Posted: December 11 2006 at 23:02 | IP Logged Quote Jerry92746
Here is the information you need to have the manifold replaced under the recall.  They will pay the mechanic for travel to your boat and replace the old iron manifold with a stainless steel one.
KOHLER GENERATOR RECALL
      Kohler Company has announced a recall campaign to address potentially fatal exhaust system failures involving certain models of their gasoline marine generators. The recall offers to replace free of charge the black iron wet exhaust pipe assembly on units utilizing L600 or L654 gasoline engines, which were manufactured from 1950 to 1989 under the following model numbers: 2R, 2A, 2.5R, 2.5A, 3.5R, 3.5A, 4R, 4A, 5R, 5A, 6.5R, 6.5A, 7.5R, and 7.5A. Failure of the exhaust pipe due to corrosion can result in carbon monoxide poisoning.
     The recall follows a March 2003 judgment of $25 million against Kohler in a lawsuit involving the deaths of 4 people aboard a vessel equipped with one of the above generators. Randolph and Lois Anderson of Joplin and two guests died on the Andersons' boat in 1999 while moored on the Lake of the Ozarks, Missouri, as a result of carbon monoxide poisoning. Attorneys for the plaintiffs argued Kohler used inferior metal to make the exhaust tube, which leaked, and that the company failed to recall the part even though four other people had died in similar incidents in 1986 and 1995.
     The black iron exhaust is being replaced with a stainless steel assembly under the recall. Boat owners who believe they have one of the affected generators should contact an authorized Kohler dealer or the company direct at (866) 866-4933. Information is also available at www.kohlerpowersystems.com.
Back to Top Printable version View Jerry92746's Profile Search for other posts by Jerry92746
