Carver
Subject Topic: Help with through hulls Post ReplyPost New Topic
Trac 2
Posted: December 05 2006 at 18:40 | IP Logged Quote Trac 2
Hello to all
I am wondering if anyone perhaps can give me some assistance here.  I have a 1988 3607 Aft cabin Carver and plan to put 2 new through hulls in this spring.  One will be just to the side of the keel near the engines and one will be forward above the water line.  Yep, I'm getting reverse heat air and want to do this work myself.
The big question I have is, When the hull is laid up by Carver, do they use solid glass OR do they use a core filler like balsa.  If the latter, I would like to plan on digging some core out around the holes and re-filling with thickened epoxy, let it set and then drill hole again.
I can't find a definate answer anywhere and thought one of you folks might have the experience.  Me, I am a rookie at through hulls.
Thanks in advance
Bob
Back to Top Printable version View Trac 2's Profile Search for other posts by Trac 2
dayodan
Posted: December 05 2006 at 19:16 | IP Logged Quote dayodan
Hi Bob,
As best as I've been able to determine Carver used balsa coring until just recently.
I recently read an approach on this Carver forum; http://carvermitch.forumco.com/forum.asp?FORUM_ID=6
but I can't find the thread.  If you post your question there, you can be pretty sure of some help.  Basically the idea was - drill a hole somewhat larger than needed for your fitting.  Glass it in and then drill a smaller hole for your fitting.  It sounded like a good idea to me.
DanO
Back to Top Printable version View dayodan's Profile Search for other posts by dayodan
AWBoater
Posted: December 05 2006 at 20:15 | IP Logged Quote AWBoater
Seems like I remember that Carver does not use any balsa below the waterline.  So you won't probably hit balsa on the lower thru-hull but might with the above waterline thru-hull.
You are doing the right thing by taking time to seal the balsa core.
While not on a Carver, I installed air conditioning myself on my last boat.  I have a synopsis of it on line if you wish to look at it.
http://members.toast.net/boatguy/projects.htm
You will access my projects page, which incidentally does have some projects that I competed on my Carver.  Anyway, look at the Four Winns Vista 268 section and you will see a project for air conditioning.
'95 Carver 325 Aft Cabin
Back to Top Printable version View AWBoater's Profile Search for other posts by AWBoater
sea of dreams
Posted: January 25 2007 at 21:51 | IP Logged Quote sea of dreams
Back to Top Printable version View sea of dreams's Profile Search for other posts by sea of dreams
sea of dreams
Posted: January 25 2007 at 22:01 | IP Logged Quote sea of dreams
Bob
I installed air on my 1986 3207 this past month, and both areas that you asked about are solid glass.  I,m almost positive there is not any coring below the rub rails on your 3607.  I also installed new seacocks, and found that Carver had that area about a quarter inch thicker than the other areas.  Good luck on the install, you will learn alot about your boat once you start to the process.
This page was generated in 1.2041 seconds.
