Last Post By: Trawler
Subject Topic: 260 sundancer cabin door Post ReplyPost New Topic
Davec
Posted: October 04 2006 at 22:38 | IP Logged Quote Davec
My upper door sliders have pulled away from the door and I can't seem to figure out how to remove the entire sliding door assembly to fix this?  Has anyone removed the door assembly to install new rollers on the bottom or to make repairs to the door?  I'm hoping the boat wasn't built around the door!
mostly happy 2001 260 sundancer owner.
Back to Top Printable version View Davec's Profile Search for other posts by Davec
bridog2
Posted: October 05 2006 at 17:17 | IP Logged Quote bridog2
http://my.boatus.com/forum/forum_posts.asp?TID=55743&KW= 280 Sorry Dave but you may be in for some trouble. Check out the link at the regular Boat US site.
2006 Sea Ray 300 DA 350 Horizon's
Back to Top Printable version View bridog2's Profile Search for other posts by bridog2
Davec
Posted: October 06 2006 at 09:11 | IP Logged Quote Davec
Thanks for the link. I would assume the the 260 and 280 are the same.
moose
Posted: October 06 2006 at 22:17 | IP Logged Quote moose
I had a 2001 245 WE and the upper sliders detached from the sliding hatch completely! The only wat to repair this is to remove the entire helm station piece and replace sliders back in track. The problem is to reattach the sliders to the sliding hatch! I traded before the repair was done, can't tell you more.
Mutual Fun Too 26 Dancer
Back to Top Printable version View moose's Profile Search for other posts by moose
Davec
Posted: October 07 2006 at 13:23 | IP Logged Quote Davec
I  investigated this further last night after speaking with a sea ray dealer.  The fact is, that the way the tracks are designed there is no other way to remove the door without removing the helm. While it looks like a lot of labor to perform this, it does not look that bad.  The door seems to rest on plastic marbles of sort and mine are really gooved bad.  I assume this was one of the issues that caused the problem.  I may have also caused the door to fail prematurely since we have done a lot of walking up/dn the steps with the door partially open. After seeing the design I think I will only use the steps with the door fully closed.
This page was generated in 0.8440 seconds.
