Marine Trader
 BoatUS Boat Groups/Manufacturer Forums>>Marine Trader
Subject Topic: MT 36’ buyer Post ReplyPost New Topic
bob gassel
Posted: September 29 2006 at 23:15 | IP Logged Quote bob gassel
I've got my eye on a 36' MT "86" going for a long boat ride, Ive boated  in Lake Michigan for some time.  Any comments or what to look for?.  Thanks Bob
Back to Top Printable version View bob gassel's Profile Search for other posts by bob gassel
djogerst73
Posted: September 30 2006 at 09:51 | IP Logged Quote djogerst73
Bob.  For info on Marine Traders go to MTOA Marine Trawler (formerly Trader)owners Association. WWW.MTOA.net.  Flybridge deck leaks were a big problem. The teak deck leaked and the non marine underlayment turns to mush.  These boats are cheap for a reason as they have a whole host of problems. Hope you can find a boat that a previous owner has reworked.Dave
David Jogerst
Back to Top Printable version View djogerst73's Profile Search for other posts by djogerst73
bob gassel
Posted: September 30 2006 at 10:16 | IP Logged Quote bob gassel
Thanks for the reply.  From what I found out they say that the pre "85" had the problem.  The MT I'm looking at is a "87" and doesn't have have teak decks.  any other info?
Thanks Bob
djogerst73
Posted: September 30 2006 at 10:31 | IP Logged Quote djogerst73
Bob.  The recommendation to check out MTOA still stands!  The many Marine trader problems are all documented and indexed on a CD.  MTOA is a group of Boat owners about 1200 strong, a very active bunch and very helpful. Annother big problem was drop center BW transmissions. Dave 1291
David Jogerst
Reflection
Posted: October 01 2006 at 17:48 | IP Logged Quote Reflection
We are recent purchaser's (this June) of a 1989 MT 34 Europa - Flybridge has non-skid, lower decks are teak. Thoroughly surveyed by the same surveyor that the previous owner has used twice before. Most recommendations had been fixed. No substitute for thorough survey! Watching a few soft spots for water intrusion, but not serious at present. Look especially hard at deck fittings for fuel and water. Most tank rot occurs because of water leakage through these fittings - the water sits then on top of the tank.
1989 MT Europa
REFLECTION
Back to Top Printable version View Reflection's Profile Search for other posts by Reflection
bob gassel
Posted: October 02 2006 at 07:31 | IP Logged Quote bob gassel
Reflection
Thanks for the heads up
This page was generated in 1.9375 seconds.
