Subject Topic: Gas Guage Fluctuates Post ReplyPost New Topic
compdr59
Posted: September 25 2006 at 17:52 | IP Logged Quote compdr59
I have a 1994 Searay 300 Sundancer and one of my gas guages will bounce from full to empty and back during acceleration. Most of the time it is stable. The other one is fine. What should I check first.
Back to Top Printable version View compdr59's Profile Search for other posts by compdr59
jrebholz
Posted: September 25 2006 at 20:35 | IP Logged Quote jrebholz
Tap the guage hard with your finger while it is in the empty point. If it returns to normal then the guage is usually bad.
John Rebholz
Chocowinity, NC
Back to Top Printable version View jrebholz's Profile Search for other posts by jrebholz
JRFUSCO
Posted: October 06 2006 at 10:08 | IP Logged Quote JRFUSCO
It may be as simple as loose ground wire.
Back to Top Printable version View JRFUSCO's Profile Search for other posts by JRFUSCO
