Regal
 BoatUS Boat Groups/Manufacturer Forums>>Regal
Subject Topic: fuel flow meter (management system Post ReplyPost New Topic
2 Screws Loose
Posted: September 13 2006 at 22:12 | IP Logged Quote 2 Screws Loose
Has anyone installed a fuel flow meter on a Mercruiser 350 magnum or similar engine? B3 outdrive
I installed a Faria "fuel manager" (flow meter) and cannot get the engine to not "run out of fuel" at high loads. Getting up on a plane or at 75% power or above. Engine leans out and quits or "lean backfires etc". when removed it runs like the old boat I love. Sweet as a kitten.
Faria says it will only flow 34 GPH. Does this engine require more? I can go on and on aout flow indications etc.
Any help.
Back to Top Printable version View 2 Screws Loose's Profile Search for other posts by 2 Screws Loose
This page was generated in 0.9082 seconds.
